03-Jul-2017 17:58:26.118 INFO [http-nio-80-exec-11] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
03-Jul-2017 17:58:27.118 SEVERE [http-nio-80-exec-11] org.apache.catalina.core.StandardContext.filterStart Exception starting filter [HAAuthenticationFilter]
javax.servlet.ServletException: java.io.IOException: The system cannot find the path specified
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:49)
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:285)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:266)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:108)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4590)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5233)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1307)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:665)
at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:211)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:595)
at org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:319)
at org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:88)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(Unknown Source)
at com.thingworx.platform.security.keystore.ThingworxKeyStore.createKeyStorePasswordFile(ThingworxKeyStore.java:87)
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:508)
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:803)
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:36)
... 41 more
03-Jul-2017 17:58:27.557 SEVERE [http-nio-80-exec-11] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class [com.thingworx.system.ThingWorxBootstrapper]
java.lang.NullPointerException
at com.thingworx.system.ThingWorxBootstrapper.contextDestroyed(ThingWorxBootstrapper.java:342)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4792)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5429)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:226)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
Hi Bianca
It would be good to specify:
- when do you get this error
- what version of ThingWorx is it
- what OS version is it
However based on the stack trace it seems the same issue as the one reported at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS248742 . It would appear the twx folder has not been created.
Hope this helps
Christophe
I am also facing the similar issue. Not able to find the solution.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
