I've created an account, I've granted it permissions, but it still won't run.Why? Please help.
Version 9.3.4
Hi @Snoopy_hu ,
Pls follow the article for the non-admin users: https://www.ptc.com/en/support/article/CS227181
Kindly revert back if issue is still present.
Bhawna
Hello @bchaudhary
I'm trying to run the mashup program with a non-administrator account, but the run screen is blank!
Hi @Snoopy_hu ,
Bhawna
Thank you very much.
You didn't explain what you want to do, so I assume it is editing a mashup?
You would have to give design time privileges.
Probably also access to some other objects/collections, might be easiest to put your user into Developers group.
