I want to install two separate thingworx instances on a single Postgres server by creating different tablespaces, DB and User names. For these I will change the postgres scripts for creating tablespaces. My platformsettings.json will look like below: Is it possible or ThingWorx will throw errors. If it doesn't throw errors will it be OK as per TWX modelling, data structure.
TWX1:
PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx1",
"password": "password",
"username": "twadmin1"
TWX2:
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx2",
"username": "twadmin2"
Would it be a prod server or dev? Do you mean 2 instances and postgres all on the same server or just two separate thingworx servers using the same db? If the latter, yes you can do that as long as the resources allow -- not for production.
If the former, that is not a supported scenario and you'll likely run into two fighting tomcat instances.
