1. Is there a way to capture the ip address of the server where the ThingWorx is installed?
2. How can we capture the ip address of the server that the user is logging in?
The getIPAddress of currentusersession is getting changed everyday because of which we are not able to fetch proper value against the IP from configuration table.
Thanks in advance,
Shalini V.
Some helpful article - "How to get addresses from Composer in ThingWorx Platform (How to get the Thingworx server/client IP address)": https://www.ptc.com/en/support/article/CS306166
