Hi all,
is it possible to block specific IPs when a thing wants to communicate with the server?
Thanks in Advance
There was a similar question before - "Is there a way to blacklist a remote device?": https://community.ptc.com/t5/ThingWorx-Developers/Is-there-a-way-to-blacklist-a-remote-device/td-p/655409
Hi @MF_10410533
Not sure about what you mean exactly by "a thing wants to communicate with the server".
If you use case is a remote edge device communicating with ThingWorx via REST API using application key as the way for authentication,
application key in ThingWorx has a IP Allowlist field by which you can configure the IP whitelist.
Note that the app key whitelist only applies to REST interface interactions, and does not apply to websocket communications. https://www.ptc.com/en/support/article/cs214898
Alternatively, you can configure ThingWorx server's firewall to block inbound communication from certain IPs.
