Import Entities from MSSQL Data provider to an instance with PostgreSQL
bot1q
I've try to export ententies (without Data) from an Thingworx Instance (8.4.5-b102) with MSSQL as Maindataprovider to an Thingworx Instance (8.4.5-b102) with Postgre.
I reseive [message: [1,018] Data store unknown error: [Error occurred while accessing the property provider.]] as Error Message.
Do you have any idea how to do this entety migration?
Hello @bot1q,
We sometimes see this error while importing multiple entities at once. I don't know why it happens, but in our case it helps when we import them in small batches or even one by one.
/ Constantine
Vilia (my company) | GitHub | LinkedIn
raluca_edu
(To:bot1q)
You need to check at import "Use default Persistence Provider".
Hope it helps,
Raluca Edu
bot1q
(To:raluca_edu)
thank you.
Same issue.
raluca_edu
(To:bot1q)
Please attach ThingworxStorage/logs/Error.log to see more info about the error.
Raluca Edu
Hello @bot1q,
/ Constantine
slangley
(To:bot1q)
Hi @bot1q.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
--Sharon
