I'd been working on Thingworx 8.1. Something happened and I had to re-install Thingworx. Now, I'm trying to import my previous work on to the same Thingworx 8.1 Composer and I get the following error:
Any help is appreciated.
Thanks in advance,
Ram
I uninstalled Java and Tomcat and reinstalled and configured the entire environment. Then the import seems to have worked. Any reason as to why this happened?
Could you please attach your full ApplicationLog.log found in ThingworxStorage/logs?
Do you have all of the same extensions installed as in your original instance?
I only had Thingworx Analytics extension in the previous installation. I have it in this installation too!
