Hi All
I recently migrated my ThingWorx project from version 8.3.0 to version 8.4.
In the updated ThingWorx Platform I am not able to import widgets such as Google Maps 3.0.3 and Progress gauge
Is there a way around it?
Regards
Hi Gunjan
Thanks for the quick response. I was able to make it work, had to enable import of widget under PlatformSettingsCongif.json
regards
Hi @ketanaga ,
What kind of error you are getting while importing the extension ?
Can you please provide the application logs and screenshot of the user which occurs on the screen .
Gunjan Aneja
Hi Gunjan
regards
