Hello everyone! I have a table (Excel, for example), the data from which I need to import into Composer. Is it possible? Or does ThingWorx import data only from files with its own format (twx.)? This is about data, not about entities.
You would not be able to import it through Composer data import. You would have to create a javascript service that consumes the data or implement your own custom java extension to do so.
Thanks!
