As I used the Menu entity in my mashup.Even if checked the default option in menu its still not reflecting in my Mashup.
Please help us on the above issue.
Which version of Thingworx are you using?
I am using Thingworx 7.4 version
Hi Aakash D24,
Just to make sure your Menu or SubMenu items contains Mashup, Hyperlink or logout? Just Menu with Menu sub-items will not show in Mashup.
Hi Ankit Gupta
I have mashup in my menu and i have marked it as default but still its not reflecting I dont know why its happening no clue on it.Please help regarding it is there a procedure to use the menu item with default part
Which entities i need to attach i am just using a mashup as an menu item and checked as default
Hi ,
Sorry for the delay .On selecting Default check box its not reflecting thats my issue
@ Ankit Gupta ,
Is this related to the default menu problem being tracked here: Menu default problem....
under Jira TW-10982?
Do you have any updates related to the resolution of this issue or that ticket?
Thank you in advance!
