in ThingWorx 7.3 in Time series chart date time is over lapping with each other. Even after giving \n which should make Date and Time in two different lines does not work any more (Overlaps) after migrating to 7.3 from 5.4. May this is happening because less space available. Is there any one facing the similar issue ?
Could you please supply a screenshot and, if possible, your entity from 5.4 so we could reproduce the issue? If a defect is confirmed, I will submit a Jira on your behalf. Thank you!
Hi Polina, Thanks for quick response.
here are the attached screen shots
Thank you for providing the screenshot. I sent you a private message.
