Hello Thingworx,
We have developed an application in Thingworx 7.3 version which contains the "Combo Box" in "List Widget" and then we have moved that application to "Thingworx 8.0" in which only "Radio Button" is available but not "Combo Box". It looks really awkward to replace a Combo Box with a Radio Button widget to enable the multiple selection for the user.
This really has spoiled the look of the page which we have designed & developed. Request you to provide us a solution at earliest best. Would be very thankful for your quick response.
Thanks & Regards,
Divya Malika
Which exact version are you using? I just checked 8.0 and 8.1 - combo box is there.
The list widget provides you with three options to get the the entries.
Hope this helps.
Thanks and Regards,
Saran
Hi Saran,
I need a "Combo Box" which will enable the user to select multiple items from the drop down list at one go. Please let me know if there is any work around for this.
This "Combo Box" is available in previous version, but not in the latest version.
Hi Polina Osipova,
We are using 8.0.0 b11. Is it because of beta11?
