Was looking for the Best Practice's to purge few logged properties which are logged in the InfluxDB ValueStream, found a Article .
and saw the below Comment in the Article:
this means InfluxDB data in Value Streams shouldn't get purged ?
@pshashipreetham CS271772 means purging data consumes influxDB greately so it may cause performace issue if you perform query/insert at the same time. For example, some data will not be logged to influxDB or query service will time out for no responding.
>>deleting data which would need to rewrite all of the shards and would become slow/unresponsive for query/insert operations
However if you do need purging data, we suggest to do it when there are few or no query/insert oeprations so the business will not be affected.
