Influx DB - ThingWorx 9.0
Saranya_S
11-Garnet
Hi
    Is ThingWorx 9.0 supports InfluxDB.
Thanks in Advance
1 ACCEPTED SOLUTION
InfluxDB 1.7.10 is supported. Refer Database Options section in the System requirements document for ThingWorx 9.0
8 REPLIES 8
When i will try to create a persistence provider for influx db it was get an error which is in the screen shot.
slangley
23-Emerald II
(To:Saranya_S)
Hi @Saranya_S.
Did you follow these instructions for installing and configuring InfluxDB?
Regards.
--Sharon
Hi @slangley ,
  Yeah. I followed those instructions.Then also it was getting error which is in the screen shot while Active the persistence provider. But now it was working only  when i gave the configuration first.
slangley
23-Emerald II
(To:Saranya_S)
HI @Saranya_S.
Are you saying that its working now?
Regards.
--Sharon
yeah. It's working with Influx db 1.8.2 version. Instead of persistence provider there is any other option to connect influx db like JDBC connections.
slangley
23-Emerald II
(To:Saranya_S)
Hi @Saranya_S.
I think this page from the Help Center should answer your question.
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @Saranya_S.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
