I am trying to setup Influxdb as Persistence Provider for ThingWorx 9.1
Where may I get thingworxInfluxDBSetup.sh script? Help says "The thingworxInfluxDBSetup.sh script is available on the PTC Support Portal in the install folder of the software download package". Could you be more precise?
And, may I go with Influxdb version 2.0.3?
Hello @Ilya
The InfluxPersistenceProviderPackage is available as part of default installation for PostgreSQL, MSSQL, or Azure SQL.
So which ever default installation you have installed previously if you go to that Installer > Install folder you can find out thingworxInfluxDBSetup.sh script and other schema scripts too.
Let me know if it resolve your query and please feel free to revert in case you have any further concerns.
Om Dukiya
Hello @Ilya
Om Dukiya
