Infotable Aggregate on multiple columns
  • June 17, 2020
  • 2751 views
Hi ,
I am trying aggregating multiple columns as shown below, i tried with putting comma separated columns but don't work. What is the solution?
when i try with only one column, the above code works fine.
Best answer by CarlesColl
You aren't using the right format, columns it's a comma separated list of values, and aggregates also:
var result = Resources["InfotableFunctions"].Aggregate({
 t: result1,
 columns: "ApparentPower,ConsumePower",
 aggregates: "SUM,SUM",
 groupByColumns: "Mkey"
 t: result1,
