Is it possible to show info table property to label chart? I have mapped the infotable property to label chart but I didn't see my timestamp column while configuring properties of widget. Can anyone suggest some solution.
I have tried to use non-numeric data as axis range without success. As per my understanding, you can set only numeric values in X-Axis. Let me know if you find a way to use StringTimestamp values in X-axis.
Hi isha,
First of all, please check your infotable out-put datashape, make sure there is a timestep column.
As I checked Lable chart X-Axis can be set to timestep.
Should you have any concern, please feel free to let me know.
Best Regards,
Lily
Hi Isha,
Could you please export your service and attach to this thread, I will have a check for you.
BR,
Lily
