Infotable to Collection Widget (Basic Only)
JY_11008628
Im very new to Thingworx and Im trying to build my capability.
I am using collection widget with data source from a service in the Thing I created.
Inside the collection widget, a mashup is already defined but it doesnt seem to load when I view the mashup.
My service doesnt require a parameter and it will give the infotable when executed.
Infotable (headers are from the datashape I made)
KPIValueColorKPIName
A1blackA
B2greenB
C3redC
UID Field: KPI
Mashup Property Binding:
"KPI": "number",
"VALUE": "string"
Child Mashup: Test Collection Data
Pls see screenshots, I cannot troubleshoot it, its not giving anything when I load the mashup
Hi @JY_11008628
Everything seems good but in Mashup property binding you have written "VALUE" instead of "Value" (which matches with infotable) .
Just Correct it.
If you still face any difficulties then post here.
Abhishek Tirkey
This is true.
But even with wrong mapping it should show the 3 collection-mashups. With empty values but the childmashup does seem to have static content which should show up.
Therefore, also make sure that you are executing the "Test" service on MashupLoaded. I assume it is not called?
If you need more about collection widget you may refer to the below link
https://community.ptc.com/t5/ThingWorx-Developers/How-to-make-a-Collection-Widget/m-p/989890
Abhishek Tirkey
