Input date to refresh infotable
DD_7886593
2-Guest
I have inserted two input date: startDate and endDate.
I have inserted this JS code in my service:
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "TFPeopledata",
    startDate: startDate,
    endDate: endDate,
    maxItems: maxValues
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for each(var row in res.rows){
            var newEntry = new Object();
            newEntry.People_in_region = row.People_in_region;
            newEntry.date_trunc = dateAddHours(row.date_trunc, -2); // DATETIME
            result.AddRow(newEntry);
The prob is don''t refresh with date selected.
I don't see the query, but anyway, your code duplicates entries ( as you are iterating over result collection variable and in the loop you are adding to the same result collection variable ). This is Javascript code not Java code I'm right?
I have used a ValueStream for data storage
var res = Resources["CSVParserFunctions"].ReadCSVFile(params);
var maxValues = 100;
var oldFirst = false;
if(startDate != undefined){
    maxValues = 5000;
//    oldFirst = true;
var params = {
    oldestFirst: false /* BOOLEAN */,
    endDate: endDate /* DATETIME */,
    maxItems: maxValues /* NUMBER */,
    startDate: startDate /* DATETIME */
var history = me.QueryPropertyHistory(params);
var result = history;
var params = {
    endDate: endDate,
    maxItems: maxValues
I got this as a result:
Results
timestamp
I think the prob with the data stream.
I don't know man, your code doesn't have much sense I'm sorry.
