Install a Free SSL Certificate from Let's Encrypt in Thingworx
Do1
Regular Member
(in response to Do1)
Re: Install a Free SSL Certificate from Let's Encrypt in Thingworx
Please note: When renewing your certificate, you need to use the same password used to generate the initial certificate. Check Tomcat server.xml if you can't remember.
I could install the SSL certificate for Tomcat by following your article. But after that, the remote device can't connect to the server (using C SDK) with error:
TW_VALIDATE_CERT: Certificate rejected.  Code: 20, Reason = unable to get local issuer certificate
twTlsClient_Connect: Error intializing TLS connection.  Invalid certificate
Do you have any clue about this problem ?
Do1
Regular Member
(in response to qngo)
I have heard of this once before from someone else.  I am sorry, I can't be of more assistance, but I believe you may need to update to the most recent version of the SDK.
Please post back here if you figure it out.
Do1
Regular Member
Disclaimer:  These are only suggestions to try and my best guesses.  Quite difficult to provide more accurate response with the information provided.
I believe your issue may possibly be caused by the default configuration of the C SKD requires that your SSL certificate is a EV certificate (Extended Validation Certificate). More details on certificates here: https://en.wikipedia.org/wiki/Extended_Validation_Certificate
You can try the following in your C SDK implementation: turn of validation by using: tls->validateCert = FALSE;
Also as previously mentioned, make sure you are using a recent version of the SDK.
Hello Duan,
Thanks for sharing useful info. I want to ask question before try it. My thingworx works on windows os instance. If I follow below steps, is it ok for my scnerio?;
1. I will generate certificate on Linux VM with your tutorial,
2. I will copy certificate to Thingworx instance which is windows os,
3. Restart Tomcat,
Do1
Regular Member
Hi Burak,
I guess it is likely to work, but it might just be easier doing it in windows.
This might be a good place to start: https://github.com/Lone-Coder/letsencrypt-win-simple/wiki
Please post your experience.
