Integrate Barcode Scanner into ThingWorx
HD_10225728
6-Contributor
Hello everyone,
I need help on the following issue: we have tablets that are supposed to scan barcodes via the camera.
1st question would be: is there a capability within ThingWorx to use the camera to scan barcodes? And if so, how could we get it and how can we use the scanned data within a ThingWorx application.
2nd question: If the scanning functionality within ThingWorx is not supported, could we integrate 3rd party websites that enable scanning (e.g. https://websdk.scandit.com/) into ThingWorx? If so, how can we use the scanned data within a ThingWorx application?
Has someone been able to achieve this? First steps on how to approach this would also be incredibly helpful.
Thank you!
1 REPLY 1
Hello @HD_10225728
As I can check there is no any inbuilt functionality within thingworx to support bar code scanner. However you can create a custom extension to achieve your requirement.
you can also refer following posts
https://community.ptc.com/t5/ThingWorx-Developers/Integrating-barcode-scanning-functionality-in-mashup/td-p/574883
https://www.ptc.com/en/support/article/CS291777
Let me know if it helps.
Bhawna
