Hello
I am trying to setup integration runtime and while doing so i am getting following errors
[Client-EndpointMonitor-1] ERROR c.t.c.c.c.n.NettyClientConnectionFactory - Exception occurred while connecting to server
java.util.concurrent.TimeoutException: timeout waiting for websocket handshake to complete
Any help will be appreciated
Hello @KV_10974131 ,
You may check the following things for the mentioned error:
Furthermore, You can refer the following article for your reference:
https://www.ptc.com/en/support/article/CS269178
Pls let know if you have any further questions.
Bhawna
Bhawna
