Integration Runtime is not able to connect to Thingworx
KV_10974131
8-Gravel
Hello
I am trying to setup integration runtime and while doing so i am getting following errors
[Client-EndpointMonitor-1] ERROR c.t.c.c.c.n.NettyClientConnectionFactory - Exception occurred while connecting to server
java.util.concurrent.TimeoutException: timeout waiting for websocket handshake to complete
Any help will be appreciated
Hello @KV_10974131 ,
You may check the following things for the mentioned error:
  • Ensure the Integration Runtime start command is correct:
    • Using integrationRuntime-settings.json:
      • java -DconfigFile=<Path To IntegrationRuntime settings> -jar <path to IntegrationRuntime-<version>>.jar
    • Not using integrationRuntime-settings.json:
      • java -DthingworxUri=http://<ThingWorx Host>:<ThingWorx Port>/Thingworx/WS -DappKey=<ThingWorx App Key>
        -jar <path to IntegrationRuntime-8.0.0>.jar
  • If IntegrationRuntime-settings.json is being used:
    • Validate host and port properties are set correctly
    • If ThingWorx is configured for SSL the sslEnabled parameter needs to be set to true
    • If Windchill authentication is used check path and password of Keystore and Truststore
Furthermore, You can refer the following article for your reference:
https://www.ptc.com/en/support/article/CS269178
Pls let know if you have any further questions.
Bhawna
Bhawna
