We're having an issue with the Node JS SDK intermittently. Normally it pushes temperature and humidity data without a problem. However, it has lately been throwing an error:
[Error] [RPi_pti]: Error calling twApi_WriteProperty() for temp - 1107
Any help would be greatly appreciated. Thanks!
On a related note, the app that we are running will unexpectedly terminate or timeout for no apparent reason. Is this some RPi config that we must change?
Nick
Hi Nick ,
Error code 1107 (TW_PRECONDITION_FAILED) specifies that The precondition for the operation was not met.
Was any recent changes made to the code , post which you are facing this issue ?
