Invisible Buttons
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Invisible Buttons
I created a template with a button that drives the page to other pages (like a home page button) and I included this in a mashup template. However when I use that template to create new mashups, it makes the buttons invisible. I tried changing the style with no luck. Is there a fix to this? or do I have to make a new function and a new button for every single page I want to make?
- Labels:
Mashup-Widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@JE_10167011 : Can you please send across the mashup/entities used so that I can try replicating this at my end? Also, please confirm the thingworx version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thingworx Version:9.3.1-b156
I used a normal button with a function to navigate with. The button then turned invisible when I use it as a new mashup from template.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
It's because of your CSS within that template there. You need to also write for the text color and other things you want to do there. It's not invisible, it just doesn't have color, it's transparent. Set the
.myBigButtonPicture .widget-ptcsbutton {
--ptcs-button-icon-dim: 300px;
height: 350px;
width: 350px;
max-height: 350px;
max-width: 350px;
min-height: 20px;
min-width: 20px;
background-color: transparent;
border: none;
padding: 10px;
And remember after you modify the template, you need to create the mashup from template again because it doesn't carry over. It works just like Paste.
