Is There a way to use the Folding Panel to responsive?
ad24
I need help also can we customize the Folding Panel
posipova
20-Turquoise
(To:ad24)
You may look into custom extensibility/developing your own solution. You may look at the existing widget and modify it at your own risk (we recommend to keep a copy for backup), the widget is located here: <Tomcat location>\webapps\Thingworx\Common\thingworx\widgets\
Attached is documentation on extensibility
posipova
20-Turquoise
(To:ad24)
ad24
(To:posipova)
Hi Polina Osipova
I have found a solution to it/We can use Header instead wih expanded option like Right/Left sidebar.
