Is ThingWorx act as a cloud?
SG_10718850
To make a simple IoT we need 3 things
1 Device- Which we will be connecting with the cloud.
2 Gateway- To provide a safe path to transfer data and services to cloud using protocols.
3 Cloud-These will be used to store data and display it using a dashboard.
I want to know whether these sequences are correct or not
Device = PLCs
Gateway = KEPServerEX
Cloud = ThingWorx
I believe there might be a lot more context behind this question, which we're happy to find, but the assumptions you made are correct.
(And there are many variations to the definitions above, which might complicate a bit the answer.)
SG_10718850
(To:VladimirRosu)
Sir I will be happy if you explain more
slangley
(To:SG_10718850)
Hi @SG_10718850.
I think what Vladimir is trying to convey is that there are many configuration options.  If you're struggling with your design, it would be best to work with one of our consultants.  They can review your short-term and long-term needs for efficiency and scalability and recommend an optimal configuration.
If you're interested in speaking with a consultant, you can reach out to the Sales team.
--Sharon
