Mashup builder is great. Easy to use and no scripting needed.
Is it possible to create business logic running in the background using drag & drop just like mashup builder instead of using scripting?
For implementing the business logic, JavaScript is currently needed. There's no UI based builder that let's you drag & drop the logic.
There might be external tools that can do that and output JavaScript code that you can then copy&paste into e.g. ThingWorx Service definitions. Though I haven't checked if and which tools really exist with such a capability.
For ThingWorx Utilities there's the Workflow Builder which at least allows drag & drop workflow design on a basic level.
There some information around it in CS242700
