We have a requirement to extract the part structure from a PVZ file. While we are currently able to display it using the ThingView widget, the goal is to extract the part structure from the PVZ file and present it in a tree grid.
Additionally, upon selecting a part in the grid, the corresponding part should be highlighted in the 3D view.
I would like to understand:
Appreciate your inputs and suggestions!
Hello @Surya_Tiwari
Thank you for your response.
We were able to get pvz files from Windchill to Thingworx. What we need is how to extract the part structure from that PVZ file (which we fetched from windchill)?
Thank you @Rocko for your response. This seems hopeful, I will validate and respond here.
Hello @AK_10385731,
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
