may I ask whether it is possible to pass data from a modal popup mashup to the caller mashup? The caller mashup is a contained mashup which requires data from the modal popup mashup.
Yes for sure, it acts exactly as any inner mashup, you have in and out parameters (the ones on the Mashup you assigned to the popup through navigation widget).
Hi @andyle13
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the @CarlesColl answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
