Is it possible to show the external .jsp pages in Thingworx Composer Mashup?
hbavirisetti
Is it possible to show the external .jsp pages in Thingworx Mashup or can we use the .jsp tags/whole jsp code in Thingworx Composer JavaScript services?
slangley
(To:hbavirisetti)
Hi @hbavirisetti .
Per the outcome of the case, it was determined that we do not support inclusion of jsp. However if you want a java specific code or a UI specific code to be included, you can develop a custom extension/widget.
If you feel this provides an answer to your question, please mark this reply as the Accepted Solution.
Regards.
--Sharon
@hbavirisetti  I believe you have a PTC case opened for this request and we will be addressing this query under the same case.
Vibhuti
slangley
(To:hbavirisetti)
Hi @hbavirisetti .
Regards.
--Sharon
