My company is developing an IIoT Lab using the Thingworx platform + Extensions.
Our objective is to learn and demonstrate internally the power of the PTC solutions. We will use this Lab to gather new projects, using it for demonstrations to our clients.
We already imported many demos that we could find here and that are demonstrated here.
We couldn't help but notice that some demos are using the SCP Accelerator, even though information regarding its installation and configuration are hard to find.
So our question is:
Hello @ArturSarlo,
The SCP Accelerator is not supported by PTC Support Services, but I have gathered that any questions related to the SCP Accelerator should be referred to Lora Estey (lestey@ptc.com). She is the right point of contact for all SCP related queries.
Regards
Bhawna
Hi @ArturSarlo
SCP Accelerator has never been a PTC product, which is likely why you're confused if it is or not.
For the time being, you should see it as a comprehensive example application that you can take, re-use, and learn from. You will continue to see more from us in this direction as we continue to leverage and build upon the solution building blocks.
Greg
Hello @ArturSarlo,
Pls let me know if you have any further queries, else accept and mark the response for the benefit of other users.
Regards
Bhawna
