Here is the situation:
I have a Mashup Master that is used as a header for several different contained mashups. I have a label at the top of the header which I would like to change based on which contained mashup is displayed in the master.
Here is what I have tried:
What is happening:
Figured it out...
Here is the new flow:
All in all, this was much simpler than trying to call the Set/Get services as well.
I think after 8.4 the mashup parameters become bi-directional, so you may use that instead of session parameter directly
Yes, that is true, but Master Mashups don't have mashup parameters.
Figured it out...
