Hello ,
Is there a way to change background color of DateTime Picker Widget using style properties ?
My ThingWorx version is 9.1.
Hello @RB_10191565
I am not certain about the style properties but you may follow the linked article to achieve similar use case:
https://www.ptc.com/en/support/article/cs326042
Kindly revert back if you face any further challenges.
Regards
Bhawna
Hello @RB_10191565
Regards
Bhawna
