Hello
I want to restrict my twx to use only Tls 1.3 is there a way it can be done?
Hello @KV_10974131 ,
I assume the linked article will contain the steps needs to restrict the Thingworx for a specific TLS version.Kindly go through the steps mentioned in resolution and share if you face any further challenges.
Hope it helps!
Bhawna
Hope it helps!
Bhawna
