Is there a way to generate more than one image on the screen using different markers at the same time? I cannot seem to find a way to do that. Thanks!
Hi Michael Davis,
I suppose you are looking for details shared in the following document: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS235093&lang=en_US
Thank you for the response. I was actually talking about 3D rendered images showing up together rather than widgets necessarily. (Object A showing up from a marker and being able to scan Object B and having both showing next to each other)
Hi Michael Davis,
This seems as a ThingWorx Studio query. Could you please confirm?
