Is there a way to translate the terms used on a Dashboard Widget?
MS_10929021
Talking about these lines in particular and the respective menus they open - for the main user base it would be very inconvenient if these were English only and make the whole widget almost wholly unusable sadly.
Running on Version 9.3.7!
I searched in the support.ptc.com this topic by entering the terms "dashboard localization".
I strongly suggest using also this search feature in the future.
The third entry points to this article which should answer your question if I got it right.
In short, in each localization table you already have tokens for them:
Hi @MS_10929021
Kindly take a look at the below article, and let us know if you have any doubts.
https://www.ptc.com/en/support/article/CS342169
Surya
MS_10929021
(To:Surya_Tiwari)
Thanks for the swift reply! From my potentially limited understanding, Localization Tokens can only be used in localizable fields of which I find no properties in the Dashboard Widget, hence the question - unless I'm missing something?
Hi @MS_10929021
Kindly find the attached screenshot, change the language for a particular user at the user journal information tab, and let me know if you have any doubts.
