I need to integrate Thigworx with corporate LDAP. The customer is using Active Directory. Is there any document available to accomplish this task? your help will be greatly appreciated.
Varathan
BTW, I don't see any entry under Directory Services in 6.5 instance I have. I am wondering whether anything changed recently.
The Help Center has some basic information on getting started with Directory Services Authentication (with an example). The Directory Services sub topic is available under the Security section.
Just to give an update on this topic, an AD connector is provided OOTB since TWX 7.3.
You can find that in the ThingWorx help center/documentation.
