Is there any way find text field widget out of focus Event.
Partha
Hi
I want to trigger some service only whenever user click outside the text field widget, But i could not find that event in text field widget..
Please help me in this regard
2 REPLIES 2
@Partha
If you do not want to use the Changed event of text field widget then you can add a button widget and use its clicked event to execute a service.
Sachin
This event does not exists on the default widget. You can create your own widget and trigger an event on the blur event of the HTML input element.
Cyril
