I wish to multiply or divide or add or subtract two numeric values in thingworx. How do I do it with use of any widget if available?
Hi Swaraj, you'll need to do that either by creating a mashup and using some services performing the mathematical calculations or you'll need to create your own custom widget, sorta like a calculator
Out of the box there is no such widget available
Hi swaraj ostwal,
As Sushant mentioned there no builtin calculator widget in Thingworx.
As a work around; per my understanding this can be done using expression widget.
You will have to use seperate expression widget for each function.
