Issue while enabling LDAP Authentication on ThingWorx
vshanmugavelayu
11-Garnet
Hi all,
I followed CS221840 to enable LDAP authentication on thingworx 7.3. I have followed all the steps mentioned. However. I am unable to login using users from AD. Below is the XML i am using to import Directory Services. Can someone pls help me connect my ThingWorx to AD?
<Entities>
    <DirectoryServices>
        <DirectoryService name="StrykerActiveDirectory" className="com.thingworx.security.directoryservices.LDAPDirectoryService" description="Apache Directory Services" >
            <ConfigurationTables>
                <ConfigurationTable name="LDAPProxyConfiguration" isMultiRow="false">
                    <DataShape description="" name="">
                        <FieldDefinitions>
                            <FieldDefinition name="server" baseType="STRING" description="<AD Host Name>" />
                            <FieldDefinition name="port" baseType="INTEGER" description="<PORTNUMBER>" />
                            <FieldDefinition name="adminBindDN" baseType="STRING" description="CN=WindchillAdmin\, SGTC,OU=Service Accounts,OU=Asean - India Tech Center,DC=pacific,DC=strykercorp,DC=com" />
                            <FieldDefinition name="adminPassword" baseType="PASSWORD" description="<PASSWORD>" />
                            <FieldDefinition name="userIdAttribute" baseType="STRING" description="userPrincipalName" />
                            <FieldDefinition name="userBaseDN" baseType="STRING" description="CN=SGTC Thingworx Users (Dev),OU=Distribution Groups,DC=pacific,DC=strykercorp,DC=com" />
                        </FieldDefinitions>
                    </DataShape>
                    <Rows>
                        <Row>
                            <server><![CDATA[localhost]]></server>
                            <port>389</port>
                            <adminBindDN><![CDATA[uid=admin,ou=system]]></adminBindDN>
                            <adminPassword></adminPassword>
                            <userIdAttribute>sAMAccountName</userIdAttribute>
                            <userBaseDN><![CDATA[ou=people, dc=thingworx]]></userBaseDN>
                        </Row>
                    </Rows>
                </ConfigurationTable>
            </ConfigurationTables>
        </DirectoryService>
    </DirectoryServices>
</Entities>
When I login using a user not already created in ThingWOrx, I get below error.
Error: LDAP authentication for user [varunraj.shanmugavelayudham@stryker.com] failed [reason: javax.naming.PartialResultException: [LDAP: error code 10 - 0000202B: RefErr: DSID-03100742, data 0, 1 access points
When I login using a user already created in ThingWorx, I get below error
Error: LDAP authentication for user [adm_vsha@stryker.com] failed [reason: javax.naming.PartialResultException: [LDAP: error code 10 - 0000202B: RefErr: DSID-03100742, data 0, 1 access points
Warning: Authentication attempt #2 FAILED for [user = adm_vsha@stryker.com]: Invalid Password
Error: Authentication failed: Please make sure the credentials are correct.
Have you enabled Directory Service?
Enabling the Directory Service
  • By default, the Directory Service entity that was imported is not enabled.
    • ThingWorx will not use LDAP for authentication until the Directory Service entity is enabled.
  • Edit the Directory Service entity
  • In the General Properties section, check the Enabled checkbox.
  • (Optional) - If you have multiple Directory Service entities configured, you can use the Priority property here to assign an order of authentication to login (where the lower the number, the higher the priority, i.e. 1 is the highest priority).
  • Save the Directory Service entity to enable LDAP authentication.
yes, I did enable the Directory Services. Did not help.
Tudor
(To:vshanmugavelayu)
In this case it looks like we're getting an LDAP error code 10: we are able to successfully connect to the LDAP server, but there seems to be a configuration issue when attempting to validate the user.  Typically, LDAP error 10 is returned when LDAP cannot follow one of the referrals (e.g. the user we requested is in a different tree).
We may want to validate the userBaseDN is accurate by connecting with a third-party tool like Softerra.
