Hello everyone!
I try to connect to my SQL server with instance name.
So standard (and working) connection string looks like that:
jdbc:jtds:sqlserver://serverAdress/DBname;useNTLMv2=true;domain=EU
And now I try to use something like this:
jdbc:jtds:sqlserver://serverAdress/DBname;instancename=myInstanceName;useNTLMv2=true;domain=EU
When I use local Database account for connection - it works. But when I try to use LDAP account for that, it doesn't work.
Maybe someone did have the same problem? Maybe I should change somehow connection string?
Thank you in advance!
Hi @lala_guliyeva.
No need to be specific regarding the changes. In this case, it sounds like a configuration issue, correct?
Regards.
--Sharon
The LDAP will help AD user login to the TWX server without password, how's that working with Database connection?
thank you for your answer! But it was local problem and it's already solved.
Hi @lala_guliyeva.
Thank you for your participation in the community. Would you mind elaborating on the solution for the benefit of other community members.
Regards.
--Sharon
Hello Sharon, no, the problem was inside of our database settings and I cannot share this information.
Hi @lala_guliyeva.
Regards.
--Sharon
