It is officially supported Thingworx 8.0 platform for Windows and Analytics 8.0?
mpagliotta
Hello everybody!
Now that it was released 8.0, I read on the guides that now Analytics is available for Windows 7,8 and 10.
Can i install on Windows Server 2008 VM Thingworx Core 8.0 and on Windows 10 VM Thingworx Analytics 8.0 ?
Is this configuration officially supported Or is better the CentOS version?
Marco
cmorfin
(To:mpagliotta)
Hi Marco
You can install ThingWorx core 8.0 on Windows 2008 and you can install ThingWorx Analytics 8.0 on Windows 10.
However you may not be able to install inside a Virtual machine. The reason is that ThingWorx Analytics requires docker.
Docker on Windows uses some virtualization feature that I don't think you will be able to use inside a VM. You probably need to run on a physical Windows 10 machine.
If you need to run in a VM, then use a Linux based version for ThingWorx Analytics so that docker can run on it.
Hope this helps
Kind regards
Christophe
Thanks for the answer!
i have a further question, now i'am thinking on 2 installation options.
It is better if i install THingworx Core on Windows 2008 VM and Analytics on CentOS VM or both on 2 different CentOS VM?
PTC, if you know, which configuration suggests? Or both configuration are the same?
Thanks again
Marco
cmorfin
(To:mpagliotta)
Hi Marco
This will be a matter of preference for you. From a ThingWorx point of view both are the same.
Kind regards
Christophe
