Hi all,
i used the .NET EMS sdk to develop edge microserver application and i found con client configurator class some properties to store properties if internet connection went down. It automatically create a log file and when connection comes online properties uploads to the thingworx foundation server by itself.
I searched for properties on same "clientConfigurator" class in documentation for JAVA SDK EMS but i can't find, i used the last release of it ( 27 october ). Anyone use it ? PTC says always on store offline messages but seems it is not implemented on java EMS, do i have to implement on my own ?
thanks
I think you are seeking a way to store offline message in Java SDK and it is mentioned in JAVA SDK developer guide Page no - 26
It states that for offline support for data and caching ,this support is only possible with binding .The remote thing on the server must be bound to the websocket over which the client application is communicating and it also describe how to use binding .
This is the guide I am following - https://support.ptc.com/WCMS/files/168410/en/ThingWorx_Edge_Java_SDK_Developer_Guide_v.6.0.2.pdf
I think I am getting your query in right direction ,do let me know if it is about something else .
Thanks ,
Mukul Narang
Hi Mukul,
How do we configure the number of messages to store offline.
Although in the document it is mentioned that offline storage is availale with binded Virtual things,
but how much values will be stored? is there a Java api where it could be set?
