Aug 5, 2014 12:54 PM UTC
JavaScript CreateThing - Thing is not running
I encounter problem when implementing service for creating Things based on my template.
Part of the script with changed strings:
var params = {
        thingTemplateName: 'XXXTemplate' /* THINGTEMPLATENAME /,</div><div>        description: 'description' / STRING /,</div><div>        name: 'xxx-11' / STRING */
// no return
Resources["EntityServices"].CreateThing(params);
// no return
Things[newNodeName].EnableThing();
When I called another service via REST API I get an error:
Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing /xxx-11 is not running Cause: Thing /xxx-11 is not running
When I open this newly created Thing in Composer and save without changing anything - it works.
When I go to .../Thingworx/Things/xxx-11 it also exists. Webpage says it is enabled.
Where is the problem? How to run this new Thing?
Aug 5, 2014 4:31 PM UTC
Hi Mateusz,
After programmatically creating a
Thing
(or any entity), you need to invoke two
Services
: (1)
EnableThing()
and (2)
RestartThing()
. Once you enable and restart the
Thing
, you are able to use it just as you would any
Thing
 created manually in Composer.
By the way, you'll want to make sure you are using proper error handling in
the
Service
 creating
Things
. For example, if your
Service
 throws an exception before the entire transaction is committed to the database, you'll wind up with "ghost"
Things
 that can only be removed by restarting Tomcat.
Adam
Aug 6, 2014 8:10 AM UTC
Hi, Thanks. It works. I'm pretty sure I've tried RestartThing() yesterday...
What do you mean by proper error handling as this functions (Create/Enable/RestartThing) have no return? Some small example?
Aug 6, 2014 3:36 PM UTC
Mateusz,
You'll want to use try-catch blocks to handle exceptions. Typically, you'll wrap your entire
Service
 in a try-catch, as uncaught exceptions from any code in your
Service
 will introduce "ghost"
Things
that only exist in memory.
