Keep menu item selected after navigating
jasperlg
Hi all,
Is it possible to keep the menu selected in a menu widget after navigating to a different mashup?
Now the menu is still visible but has no item selected after navigating. It is essential to use the menu widget and not the collection widget, because we need the return functionality in the browser.
Thanks.
Jasper
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:jasperlg)
Hi @jasperlg.
From a review of the case, it was determine that it is not possible to keep the menu selection after the click out of the box.  Some options available to you are:
  • Submit a feature request on the ThingWorx Ideas Board
  • Look into CSS styles and try modifying Mashup CSS (class active)
  • Engage with Professional Services to assist with developing the functionality to fit your needs.  To do so, you would need to reach out to the Sales team.
--Sharon
6 REPLIES 6
slangley
23-Emerald II
(To:jasperlg)
Hi @jasperlg.
Have you looked at using a Master?  Here's a link to more information.
--Sharon
jasperlg
(To:slangley)
Hi @slangley
Thanks for the reply.
Yes, the issue I'm talking about also occurs in masters, I would only need the feature in masters and not in regular mashups.
Kind regards,
Jasper
slangley
23-Emerald II
(To:jasperlg)
Hi @jasperlg.
Are you using multiple masters?  We suspect the issue may be a configuration issue.
If you would like we can open a case on your behalf and review via a WebEx.  Let me know if you would like to take that approach.
--Sharon
jasperlg
(To:slangley)
@slangley
In my project I'm using multiple masters. In my desktop version of the project, I'm using multiple masters in one mashup, in the mobile version there is only one master in a mashup.
I would definitely like to have this reviewed. If this requires to open a case, then we can do that.
Kind regards,
Jasper
slangley
23-Emerald II
(To:slangley)
Hi @jasperlg.
I have created a case on your behalf.  Someone should be reaching out to assist shortly.
--Sharon
slangley
23-Emerald II
(To:jasperlg)
Hi @jasperlg.
--Sharon
