Hi guys.
I have a question or ask about kendo scheduler event coloring.
I created a mashup for daily action plan. I would like to coloring the events depends on event status (i.e. "Done", "Deleted", "Open", etc.)
As I saw, on site description the scheduler widget contains 13 exact named columns or field. I use 22 columns in datashape. I tried to configure the widget through the schema model and resources, but it is not working.
I do not no what is the good way to solution. I tried to create template or script, but I am not an expert,I could not solve.
Here is the configuration:
"footer": false,
"views": [
{"type":"day", "selected": true, "allDaySlot": false},
"week",
"month"
"schema": {
"model": {
"id": "Id",
"fields": {
"taskId": { "from": "ID", "type": "number" },
"title":{ "from":"Statusz", "type":"string"}
"resources": [ {
"field": "title",
"dataSource": [
{ "text": "Open", "Statusz": "Open", "color": "#0000FF" },
{ "text": "Closed", "Statusz": "Closed", "color": "#00FF00" }
Need anything else for it?
I followed the descriptions on Telerik site, but i could not solve the problem . If somebody have idea for solution, please answer.
Thanks in advance.
