KepServerEX 6.10 get closed automatically when Opened
psp316r
Installed KepServerEX 6.10 and it gets closed automatically when Opened
@paic  @slangley @c_lowy
Shashi
1 ACCEPTED SOLUTION
Hi @VladimirN ,
Thanks for quick response, but the Article didn't help !!
The issue was, Java 8 was not installed in the PC, which Caused this issue. Once the JAVA 8 JDK is installed and path is configured, issue was solved, KepServerEx is working normally now.
Shashi
3 REPLIES 3
VladimirN
(To:psp316r)
Try this tip - "Installation fails with "Installation Wizard Ended Prematurely" error in PTC/Kepware products": https://www.ptc.com/en/support/article/CS335922
Hi @VladimirN ,
Shashi
VladimirN
(To:psp316r)
I'm glad you solved your problem.
