Kepware - Atlas Copco PF6000
eazzarito
Hi everyone,
I need to configure kepware for reading Atlas Copco PF6000 data.
I set as model connect "open protocol".
When I set the parameters for "Data Properties" and then access the Quick Client, I see the connection has a "Bad (Out of Service)" quality.
KEPServerEX 6.12. V6.12.325.0
Anyone could you help me?
Please find image attachments.
Thank you,
Best Regards
3 REPLIES 3
kazunari
(To:eazzarito)
Hi could you share your EventLog and Device configuration?
Hi everyone,
I was able to link several tags and read the value. I still can't read the value from the custom tags.
Could you help me with the configuration?
I need to read the tightening steps.
Thank you,
Best Regards
Hi
I have similar issues with DAQ from Atlas copco 4000 & 6000 series.
Can you share how you were able to connect and extract data
my mail id is ara.arvind@gmail.com / ara.ale@ashokleyland.com
thanks
Arvind
