Kepware IOT Gateway JAVA JRE
VM_8674327
For the IoT Gateway to run, KEPServerEX requires a working 32-bit Java JRE or full JDK installation version 7 or higher. At this time, a 64-bit JRE or JDK is not supported. I Just wanted to know if we can use AdoptOpenJRE instead of 32-bit java JRE?
aservetas
(To:VM_8674327)
The only third-party tested versions of Java at this time are OpenJDK & Correcto (Amazon’s openjdk) as shown in this knowledge article here:
https://www.ptc.com/en/support/article/cs325523
If you attempt to use an alternate version of Java, proper functioning of the IOT Gateway plugin is not guaranteed and cannot be supported.
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
1 REPLY 1
aservetas
(To:VM_8674327)
Best regards,
Andy Servetas
